kuld33p
Guys, This is my first post ever to this place. after alot of searching and reading.. I finally decided to ask you my specific questions.
I am looking for an 42" TV..
Plasma or LCD.. any one which is better (heard plasma is good)
Budget 50k
Requirements :
Need 1080p for sure.. (may be this is in my mind.. i would be playing games on PS3 and movies off my HDD.. will 720p Plasma deliver a full HD experience on 42" plasma.. ok sorry i confused you guys.. I am asking what is the difference between a 720p Plasma and 1080p plasma if we run a PS3 or 1080p movies on it.)
well that is all at the moment..
I saw some Panasonic ones.. but plasmas which are full HD are out of budget..
I checked 2 42 inchers on Panasonic India site.. G10 and S10..
Could someone tell me what is the difference.. as per the shop keeper only difference is the G10 got 600Hz sub field drive and S10 has 550..
Edit : one more thing.. if G10 has resolution of 1920x1080, does it mean I will be able to use my PC with this resolution and use it as a monitor.. ( or its a myth and i am running after something which is not even practical)
Budget 50k
Requirements :
		 people are going for LCD and Plasma is dying out.
