best mid priced dac
nandac
is it safe to assume arcam's rdac as one of the better products in mid priced (under $500) DAC segment (including vdac, dacmagic, beresford etc) ?
also if the intended use is primarily play music from a computer, is the rdac significantly better in terms of sound quality than products like HRT streamer?
appreciate the insights.
MF M1 is being discussed a lot these days. Blasto found it very good. Price is about 32-35k IIRC.
It also has async usb, and has a good hi-fi build.
I've heard good things about Asus Essence One as well. You may want to consider that as well.
Hello,
I am having AP DAC (acousticportrait.com) expensive and it is a one time investment. It also has all required connectivity.
Venu
Refer to the thread 'Hot deal for monitor speakers' it has some detailed levels of DACs comparison.
In short
Caiman< CA DAC< rDAC< M1/Audio-GD
all of the above are below 500 except for M1 which is 33k at audio people.
Check with Ravi_d on how to procure audio-gd from China, it's a good dac below 500 usd.
Yep, but no idea how mavrick compares against all these dacs I read about today.
Musical fidelity also has tube amps which i see on audiogon but theres so many of so many different brands how does one even pick!
mavrick D2 is a good one.Better sound stage & overall musical.
