my system is far from perfect. I had space limitations on my desktop and hence the design. You can definitely extract more from this in a better cabinet. The volume is in the recommended range. the size is wxhxd - 7.5"x10"x9". its loosely based on the dmarken7 or something like that (mini onken for alpair 7). did it with the help of planet10 in diyaudio. He also recommended a supporting brace for the driver, but i havent put it yet. I am using something like 17mm mdf (advertised as 19mm) for this.
I am using m-audio revolution 7.1 sc as the source and topping tp20 as the amp. I am still waiting for my sub amp (future sub - tb1363sb and jack hidley's plate amp), presently using the mx5021 sub. Its junk:lol:. I crossover at 120 for rock metal etc and 80hz for other music. I run it full range sometimes late in the night, it has lean but very nice bass. The power is seriously limited in this case. sims show max 8w and excursion is exceeded. With a sub, I havent gone beyond 1-2 o'clock on the topping, it gives good volume for my small 11x11 room in nearfield. the cone hardly moves. I think it will hit the thermal limits before the excursion limit (4.5mm xmax). That reminds me, I need to get chamfering done for the cab.
the beauty is not in the cab or the setup. its the driver, its magical. You can try the pensil 7 design for FS or dmarken7 (cant get the onken nomenclature right
) for small spkrs.
Make sure it meets your needs first. its a very niche drivers, with some shortcomings. If it does, it will give you a lot of pleasure. Its only 85$ for a driver. Considering it doesnt need a tweeter and a crossover, thats one hell of a vfm deal.
