best sub for 30k budget
gr_babu
hi
pllz reccommend the best sub for 30k budget.
mostly for movies and music
thx
Please search forums for various threads and discussions on very similar topics.
Well, if music matters to you significantly then I will have no hesitation in recommending the EPOS ELS subwoofer to you.
In this budget it is probably the best musical subwoofer you can go for. It may not make your heart stop when used for HT purposes but it is certainly adequate.
I have bought it recently and my experiences can be found at this thread:
http://www.hifivision.com/speakers/1770-subwoofer-choice-2.html
