bi polar speakers
Curious to know who suggested to buy 5 bipoles.
If it was a seller maybe people should consider to blacklist him on this forum by not recommending that seller. What we want is for people to make money by ethical means.
If the seller himself didnt know that bipoles are not for center and fronts, then in my opinion, he has no business selling hifi stuf. Let him sell BOSE or else ;)
the seller is just a guy who does this as part time , from Bangalore .. and he probably didn't know I think .
any way I am confused with two speakers please suggest which one to select as front .
1) PIONEER S-Z84D 3-WAY BOOKSHELF
3- WAY
8" INCHES WOOFER
1 MID RANGE
1 TWEATER
MADE IN JAPAN
I think it is not 8 ohm but 6 ohm.
used one .
____________________________________________
2nd option ).
Technical specs for Magnat Monitor
Supreme 100
Descriere 2 way
Putere RMS 55 W
Putere dinamica 110 W
Raspuns in frecventa 42-34.000 Hz
Difuzoare 1x 4.5 woofer-midrange
1/2 dome-tweeter
Impedanta nominala (EN 600065) 4-8 Ohms
Dimensiuni 235 x 145 x 195 mm
Alte caracteristici Low resonant, stable MDF
cabinet
High-quality wood decors, highlighted with
a black baffle
Removable cloth grille
Tweeter with 25 mm silk dome and ERA
front plate for a balanced reproduction and
constant radiation
Woofer and woofer-midrange with low-
distortion, coated cellulose cones
High quality crossover with phase correction
Gold-plated screw terminal
Metal- and rubber spikes included.
so which one will serve me better with denon 1612 and my rear Bipolar surrounds (6 ohm , 100 watts).
both are same price range 6-7 k .
pioneer is bigger , got woofer (I guess 1612 can run it ?) while monitor 100 is new and good looking but it is different ohm (8ohm).
please give me your feed backs :-)
