Bi-wiring
These things depend on the speaker design a lot. I have seen ATC owners swearing by bi and tri wiring while some other do not find much difference..
I am using AP Book Shelf Speakers which has 4 Connectors , and Amp is sansui B2102 , which has 8 Connectors ( 4 for speaker A, 4 for speaker B )
I am just looking for connection method
Tanoj
Hello Friends,
I see that bi Wireing has been explained in detail in this thread, however i wanted to re check
I have a sansui B2102 power amp there are 8 speaker sockets ( 4 for Speaker A, 4 For speaker B ) at the back, and two Switches in the front ( Speaker - A , Speaker - B )
right now sine iam using single wiring so i have connected only to the Speaker - A sockets and the Speaker A switch when pressed sends the signal to the speakers
so to do biwiring i should first remove the jumpers from the back of the speakers, then connect wires from Speaker - B socket to the top sockets of the speakers, and then Press both the switches in the front ( Speaker - A & Speaker - B ) correct ?
Thank you
Tanoj
Just biwiring means removing the jumpers and running two lengths of wire from each of the speaker terminal of the amp to the speaker's binding posts.
For biamping - different amps are used for each of the speaker wires.
(using A and B speaker outputs together in many amps may do the same thing but may also overload the amp, as far as I understand)
Tri-amping is similar to bi-amping and is done with three amps and speakers having three binding posts for the drivers.
If the cross over is removed and placed before the amps (can be in preamp) then it becomes an active system.
Please find the picture of my Amp and speakers terminals attached
back of the amp there are 8 sockets, and in the front there are two buttons to turn on speaker A and speaker B
option 1 : connect cables from speaker A sockets to the speakers sockets
Option 2 : Connect Speaker A sockets from the Amp to the lower terminal/sockets of speakers and connect Speaker B sockets from the AMP to the upper terminal/socket of the speakers, and press both A & B Button to start the signal flow from both the cables ?
Which one is correct ?
Tanoj
I am worried that connecting the HF to the Speaker B may burn my tweeters, if its not meant to connect that way, so double checking
Experts please pour in your inputs
Tanoj
It may harm your amp. Find out the lowest impedance it can handle if both the speaker outputs are used together.
there is a impedance selector at the back of the AMP which is set to 8 Ohms since my speakers are also 8 ohms
so if i press both the buttons A & B i believe the signal will start flowing from all the 8 sockets of the amp ( speaker A & Speaker B )
so do i connect the speaker A sockets to the tweeter and Speaker B sockets to the Mid/woofer ?
Tanoj
You can try setting your amp to the minimum impedence, wire woofers from A and tweeters from B set of connectors, remove the jumpers from the speakers and use both A and B together.
Listen to some music and keep the volumes low. If you don't find any difference, go back to the way you had connected the speakers earlier.
This will not be exactly bi-amping but should be better than simple biwiring.
(I had tried it in some older Sansui and NAD amps but didn't find any major difference so switched back to the conventional method of connecting speakers.)
Hi Friends,
Finally Connected the Speakers to the amp, connected the tweeter to speaker B socket and woofer to speaker A, switched on Both A & B,
Moved the Impedance socket to 8 ohms as it is written that if both A + B is used move the socket to right side for the 8 ohms
i used the telephone wire for connecting the tweeters...
Played the disk which i ve been listning often this days ( Best women Audiophile voices )
same old settings, same pre amp ( Pass b1 ), same CDP ( Nakamichi MB 2 ) ..... and yes there is difference, specially with the sounds of cymbals, guitar etc
i feel as if i have replaced my amp with an other ... iam going to get a proper interconnects and speaker cables ....
if you guys have option available there is no harm trying it out .....
Thank you everyone for your valuable inputs
Tanoj
I have been using Vandersteen speakers for more than 10 years now which are designed to be biwired. Here is what Mr. Richard Vandersteen has to say about biwiring. I am running the speakers in double biwire configuration. Hope it helps. (Note: Mr. Vandersteen does not manufacture or sell cables.)
murali
Bi-wiring uses two separate sets of speaker cables to connect a single pair of loudspeakers to an amplifier. Coupled with a crossover designed specifically for bi-wiring, it offers many of the advantages of bi-amplifying the speakers with two separate amplifiers without the cost and complexity of two amplifiers.
We began experimenting with bi-wiring back in the early '80s, an era when horizontal bi-amplification was considered the ultimate way to drive quality loudspeakers. (Horizontal bi-amplification used one amplifier to drive the low-frequency section of a speaker and a second amplifier to drive the high-frequency section.) We noted that speakers sounded better when bi-amplified by two amplifiers than when driven by a single amplifier. Surprisingly, this superior performance was evident even when the speakers were bi-amplified by two identical amplifiers at a low volume level and the amplifiers were each driven full-range without an electronic crossover. We initially believed that the double power supplies and other components of two amplifiers were responsible for the improvement, however building amplifiers with twice the power supply and doubling-up on other critical components failed to provide the bi-amplification benefit.
So we looked at the speaker wires. With two amplifiers, bi-amplification used two sets of speaker cables so we experimented with doubling-up the speaker wires and with larger wire. Neither duplicated the bi-amplification improvements. Then we considered that in a bi-amplified system, one set of wires carries the low-frequencies and the other set of wires carries the high-frequencies. We modified a speaker's crossovers to accept two sets of cables and present different load characteristics to each set so that the low-frequencies would be carried by one set of wires and the high-frequencies by the other set of wires. Finally we heard the sonic improvements of bi-amplification with a single amplifier.
Additional experiments with a Hall Effect probe revealed that high-current bass frequencies created a measurable field around the wires that expanded and collapsed with the signal. We believe that this dynamic field modulates the smaller signals, especially the very low level treble frequencies. With the high-current signal (Bass) separated from the low-current signal (Treble) this small signal modulation was eliminated as long as the cables were separated by at least an inch or two. (To keep the treble cable out of the field surrounding the bass cable.)
The crossovers in Vandersteen bi-wirable speakers are engineered with completely separate high-pass and low-pass sections. The bass inputs pass low-frequencies to the woofers, but become more and more resistive at higher frequencies. The treble inputs pass high-frequencies to the midrange and tweeter, but become more and more resistive at low-frequencies. The output from the amplifier always takes the path of least resistance so deep bass frequencies go to the bass input (Low impedance at low-frequencies) rather than to the treble inputs (High impedance at low frequencies). For the same reason, treble frequencies go to the treble input (Low impedance at high-frequencies) rather than to the bass inputs (High impedance at high-frequencies). At the actual crossover frequency, the output from the amplifier would be divided equally between the two inputs as they would both have the same impedance at that frequency. Because of the different reflected impedances of the cables, the crossover between the woofer and midrange actually occurs at the wire ends where they connect to the amplifier.
The benefits of bi-wiring are most obvious in the midrange and treble. The low-current signal to the midrange and tweeter drivers does not have to travel on the same wire as the high-current woofer signal. The field fluctuations and signal regeneration of the high-current low-frequencies are prevented from distorting or masking the low-current high-frequencies. The back EMF (Electro-Mechanical Force) from the large woofer cannot affect the small-signal upper frequencies since they do not share the same wires.
The effects of bi-wiring are not subtle. The improvements are large enough that a bi-wire set of moderately priced cable will usually sound better than a single run of more expensive cable.
All the cables in a bi-wire set must be the same. There is often great temptation to use a wire known for good bass response on the woofer inputs and a different wire known for good treble response on the midrange/tweeter inputs. This will cause the different sonic characteristics of the two wires in the middle frequencies to interfere with the proper blending of the woofer and midrange driver through the crossover point. The consistency of the sound will be severely affected as the different sounding woofer and midrange drivers conflict with each other in the frequency range where our ears are most sensitive to sonic anomalies. The disappointing result is a vague image, a lack of transparency through the midrange and lower treble and a loss of detail and clarity.
Some of the benefits of bi-wiring are from the physical separation of the high-current bass and low-current midrange/tweeter wires. So-called bi-wire cables that combine the wires in one sheath do not offer the full advantages of true bi-wiring although they may be an excellent choice for mono-wiring the speakers.
The cables should all be the same length. This is not due to the time that the signal takes to travel through a cable, but rather that two different lengths of the same cable will sound different. If the cables connecting one speaker are a different length than the cables connecting the other speaker, the resulting difference in sound between the two speakers will compromise the imaging and coherence of the system. If different lengths of cable are used for the bass and midrange/tweeter inputs of the speakers, the effects will be similar to those experienced when using two different cables as described above.
Since short runs of speaker cable sound better than long runs, consider placing your electronics between the speakers rather than off to one side. If for convenience or aesthetic considerations, the electronics must be located a considerable distance from the speakers, it is usually preferable to place the amplifier between the speakers and use long interconnect cables and short speaker wire.
Back To FAQ Page
