Boston hi q 8 inch Diy speaker project
If you go by its parameters, it would demand a 250 liter box. It is of course not correct.
What port length have you used and how did you calculate it?
Also why the port is not flared at the exit?
I haven't calculated port length,this is my first project and it's just to see how good is the driver,there is one more pair of the drivers left and i hope to build a proper speaker and try to fix the problems such as weak treble and low end.
I think trying to coax bass out of this speaker in the sub 100 hz area is a lost cause. If you can't have a sub, then a port might help keep the LF response up in the 100-250hz region.
I am using mine with a Peerless TL25SN
Did you use a crossover?
