Hello all,
I started fabricating 16:9 projection screen.
The frame work in progress. Hopefully to finish by this weekend.
Two 1.5" X 1" aluminum rectangular tube of 12' for the frame brought.
http://1drv.ms/1KNy741
Cut into 224 cm and 127 cm as internal length at 45 degree angle.( done at local workshop). Outer dimensions are 231 cm and 134 cm.
http://1drv.ms/1JGx8pa
http://1drv.ms/1JGx9th
Drilled holes on corners to attach L clamps.
http://1drv.ms/1JGxvjE
http://1drv.ms/1L2rPAE
http://1drv.ms/1L2rTAG
http://1drv.ms/1BZH59h
I used hand riveter for the first time. The results were satisfying.
http://1drv.ms/1L2s6DL
Cost incurred so far
Aluminium tube : 500/- approx
L clamps : 100/-
rivets and screws : 50/-
I brought Hand riveter to include in my tools. so 500/- extra.
Stopped joining the frame. Thought holes to be put on the frame for fixing the cloth. There is a confusion here.
regards
girish
L clamps : 100/-
regards
girish
