iaudio
madmax, as ruenigma and doors have pointed out, audition again and also allocate budget for an entry level dac. Just give it some time, you will get clarity on the issue
If not we all are here to help!
If most of your Music is in the digital format then re-look at your setup and look for a Digital Amplifier which keep your files in digital domain and does the conversion at the output stage through the filters, now instead of spending money on a cd player look at a Digital Network Players which have the capability of playing your music either off your Network or the USB Hard Drives and since these are designed at the target audience which play mostly MP3s or lossy music so it does a much better job in playing the same content and gives a much better results.
Look at the Media playback solutions from the likes of NAD or Marantz and there you should be able to find the answers to your solution.
Like mp3 Will the SQ improve if Flac is the source to DAC
Sent from my iPad using Tapatalk HD
The result:
ipad: sounded good. but could not hear good seperation, crisp instruments. The sound was percentage wise in comparision to the cd was at about 35 percent
phone: played my samsung galzaxy not via poweramp, The sound was percentage wise in comparision to the cd was at about 20 percent
laptop: played on a nomal laptop, courtesy the sales guy. This sounded the best
probably at about 35 -40 percent of the cd
All of the above was connected to the m1 dac.
Ok looking at what you have finalized so far (PM5004 + 11L2) it seems like you have a budget of 50k. Or thereabouts.
So if we look at a slight twist in the tale, reconsider your options.
1. Marantz PM 5004 - 17500
2. Audinst HUD MX1 - 9000
3. CDs That you like from Flipkart/Rhythhouse/Saregama - avg 100 each total 35 discs- 3500
4. Just now just look for a different set of speakers in 20k.
You can look at
PSB Alpha B1/Image B4
Paradigm Atom Monitor
MS Aviano 1/2
Wharfedale Diamond 10.2
Tannoy Mercury etc
QA 2020
Dali Concept 1
All these are good speakers for the price. So all of this comes below 50 and leaves some room for buying some quality interconnects/cables as well.
So instead of fretting over MP3 performance issues and working towards addressing it with bad non-resolving system lets tackle the issue head on.
Hope this helps.
Nothing like having the whole music collection on your mobile. Listen to them on the go through headphone(analog o/p) and get real hi-fi at home thru digital o/p and DAC way![]()
