Buying WDTV Live HUB, Logtech Harmony 700
Vijay_s
bangalore
I am planning to buy WDTV Live Hub, Logitech Harmony 700 & Canon ELPH 300 HS camera from Amazon and getting it through spouse travelling back to India. Can I use these items straight out of box considering the voltage difference in both country.
1.In case I need a power adapter suggest one
2. Do NTSC PAL format difference will be an issue?
WD Live Hub - $179.99
Amazon.com: Western Digital WD TV Live Hub 1 TB Media Center: Electronics
Logitech Remote - $86.99
Amazon.com: Logitech Harmony 700 Rechargeable Remote with Color Screen: Electronics
Canon Cam $249.95
Amazon.com: Canon PowerShot ELPH 300 HS 12 MP CMOS Digital Camera with Full 1080p HD Video (Black): Electronics
Congrats!
Yes, you can use these items straight out of box, as these adapters will work on 110-220V.
NTSC/PAL will not be an issue.
Enjoy!
Hi svkndv,
So, did you make the purchase? Can you confirm its fine to get it from US?
reju, are u sure it works in both 110/220 volts?
I am planning to ask my friend to bring a WDTV Live from US. Need confirmation to these questions asap.
TIA
Hi svkndv,
Can we move the recorded video files to a PC and archieve it on DVD on the WD TV Live media centre.
N.Murali
Hi svkndv,
TIA
I got it two days back and it is working fine with 240 watts. Power cord shows 110-240 range. I registered the device online, as the region of buyer and seller different device qualified for only out of region warranty.
Hi svkndv,
N.Murali
Yes Murali, I connected it through Network cable (LAN) and transfered content from PC to WDTV. So its possible to copy both ways.
