Cabinets / Enclosures for DIY-projects
hydrovac
Hyderabad
Hi all!
I was looking for an enclosure for a pre-amp I am building... I really would like something a little nicer preferably pre-drilled one with two knobs (one for source and one for volume)... couldn't find any real good leads on this.
There are couple on E-bay but either they have logo/text I do not need or description is too vague that I do not even know what diameter the holes are... and are expensive.
I came across this thread on HFV... he can do customization on your enclosure.
For now I've gone ahead and ordered two cabs... with 6mm Al face plate + some holes & other bits, it came to 2500 + shipping.
Not bad at all, and it seems for now to be the most "local" solution I could find.
There will always be the next project! ... I'll certainly be keeping an eye on Beginner-N for future builds.
Pics of enclosures:
20190421_094403.jpg20190421_094551.jpg20190421_094805.jpg20190421_094900.jpg20190421_095327.jpg20190421_095335.jpg20190421_095418.jpg
Is that price (Rs.2500) for one cabinat or two?
Also please share the thread link from where you ordered.
The price is 2.5K per enclosure + shipping... you can ping Nishant for any other details.
Hi all!
Pics of enclosures:
View attachment 35381View attachment 35382View attachment 35383View attachment 35384View attachment 35385View attachment 35386View attachment 35387
Thank you for your kind word.
Means a lot when you see satisfied user. Always looking for any improvements that you have after assembly, so that others can be benefited.
Nishant
Hi all!
Pics of enclosures:
Nice work Nishant.
This is really great work, Nishant. Can you please tell us a bit more about options you can provide? Are these cut on laser, or some other automated cutting machines? The holes look really neat -- definitely not hand-drilled. Can you do any cutouts on front and rear panel? What about doing groove (a straight line a few inches long, maybe 3-5mm wide, maybe 2mm deep, where one can then drill small holes for LED indicators)?
Thank-you for appreciating.
Front plate is machine drilled. And yes all kinds of designs on front plate are possible. It just adds to the cost. These are made to order.
