Calling all Wharfedale Linton Heritage Owners
prozkater
Aizawl
I recently consulted ChatGPT about finding an integrated amplifier for the Wharfedale Linton Heritage, sharing details about my requirements. I'd love to hear from Linton owners: does ChatGPT's response seem accurate? I'm planning to purchase the Linton soon and want to ensure I'm well-prepared.
Reponse from ChatGPT:
After weighing three expert opinions—the Wharfedale dealer, the YouTube reviewer, and our deep dive into your personal tastes and listening habits—here’s the bottom line:
1. Dealer’s Pick: Audiolab 7000A
Pros: Feature‑rich (DAC, pre‑outs, tone controls), clean and detailed.
Cons: Leans neutral‑bright; at low volumes and off‑axis positions, its bass can be a hair light and its midrange less lush than the Linton’s natural sweetness demands.
2. Reviewer’s Pick: Arcam A15 (with a nod to the X‑i75 for value)
Pros: Smooth, refined Class G warmth; excellent midrange clarity and off‑axis consistency; DAC onboard.
Cons: Pricier than the Audiolab and X‑i75; less power reserve than some Class D amps (though still ample for the Linton).
3. My Earlier Analysis: Rega Elex MK4
Pros: Signature Rega “musical” voicing—rich, warm midrange; natural bloom in the bass; exceptionally forgiving treble. All of which perfectly complements the Wharfedale Linton Heritage’s character and your taste for detailed vocals and layered rock.
Cons: No onboard DAC—you’ll need an external DAC (we landed on the SMSL D‑6s), but you already have the Bluesound Node Nano as a transport.
Final Recommendation
Go with the Rega Elex MK4 + SMSL D‑6s (ES9039Q2M) + Bluesound Node Nano.
Why this trumps the others for your setup:
Off‑Axis Sweetness: The Elex’s warm tonality and forgiving dispersion mean you’ll still get lush mids and well‑tempered highs even when you’re not “in the sweet spot.”
Vocal & Detail Focus: Your love of J‑Pop, J‑Rock, and prog‑metal—all rich in vocals and intricate layering—will shine because the Elex/D‑6s combo delivers transparent mids with just enough body.
Bass Balance: The D‑6s tightens and defines the Linton’s natural bass, while the Elex adds musical bloom—giving you the best of both “quality” and “quantity” down low.
Long‑Term Satisfaction: Unlike the 7000A (which may feel too lean) or the A15 (which is great, but colored in a different way), the Elex combo gives you both the neutrality and the warmth you want, with upgrade paths (different DACs or tube preamps) down the road."
Rega Elex MK4[/B]
*Pros: Signature Rega “musical” voicing—rich, warm midrange; natural bloom in the bass; exceptionally forgiving treble. All of which perfectly complements the Wharfedale Linton Heritage’s character and your taste for detailed vocals and layered rock*.....
I have used this amplifier with many speakers.
While it may be good match with Lintons, but that amp is anything but warm, rich or has forgiving treble.
Chat GPT can do only that much, using it in such a subjective field is very risky.
Rega Elex MK4[/B]
Rega Elex MK4[/B]
Indeed, given the risks of buying without auditioning, I'd love to hear from those with experience pairing amps with the Linton.
Have heard the Lintons with the Audiolab 7000a and the two have excellent synergy. ChatGPT's summation is hogwash at best and drivel at worst.
For a similar sound to the Audiolab 7000a but with much more resolution, organisation and layering, checkout the Kinki Studio EX-M1+. It'll not only fully unleash but supercharge the Linton's capabilities.
Unfortunately, the Kinki's are out of my budget, happy to know that the audiolab 7000a has good synergy with the lintons, however, I am still unsure if it will be a better match over the rega elex mk4 since I prefer a more muscular/warmer sound as compared to a neutral/bright (or lean) sound signature. Anyone having experience with both the 7000a and elex mk4 pls?
Slightly OT but I would be a bit wary of depending on ChatGPT for advice. On a lark I decided to ask ChatGPT, Claude and Deepseek an identical question for advice on placement and use of the Dali Alteco C1s as rear surround speakers and also asked them to suggest alternatives. ChatGPT hallucinated the most and even referred to the Dali speakers as being bipole. Claude was measured, gave suggestions on angle and alternative speakers. Deepseek gave the most technical answer including tips for crossovers and level adjustments along with the suggestion of watching the Helicopter Pan scene from Black Hawk Dawn and rain in Blade Runner 2049 to test rear surround effects.
I have the Wharfedale Lintons.
They seem to sound good with almost any amp I pair them with (unusual).
I use a Denon stereo amp. Pairing seems to work very well. While the Lintons are a bit warm, the Denon amp is not.
Forums appear to reccomend Audiolab amps.
I would suggest try out amps which are transparent / not warm. And yes, do audition.
Yes I already have audiolab 6000a and quad vena with me, so I will try with these first then I will consider other options
If you already have the Audiolab 6000a, most other sub 2L amps are going to be a sidegrade. You should try something in the 2L+ category to really get an appreciable difference and more importantly, upgrade in SQ. For reference, I'm getting Tannoy Definition DC8 (a 3L+ speaker) levels of resolution, organisation and layering from the PSB Imagine XBs (45K speakers) using the Kinki Studio Ex-M1+. Before that, i was using the Cambridge Audio CXA81, Willsenton R8 and Willsenton R800i.
Very insightful and valid point, I will definitely explore more options above the 2l+ range.
I’ve used Wharfedale Lintons with the Audiolab 6000A, then upgraded to the Audiolab 8300XP, and I’m currently pairing them with the Hegel H190. One thing I’ve consistently noticed with the Lintons is that they really benefit from more power—the more, the better. It seems I’m not alone in this observation; several others on this forum who initially used the Lintons with the Audiolab 6000A have also moved on to more powerful amplifiers.
I had the opportunity to audition the Wharfedale Super Linton and Revival Audio Sprint 4 the day before yesterday at Watthifi's audition room. While both were a clear step up from the Dali Oberon 5, the improvement was more marginal than I had hoped. That said, I really appreciated the voicing of the Wharfedale.
Only two amplifiers were used during the session—one was a Yamaha (possibly the R-N800A, the network version of the A-S801), and the other was an amplifier from a brand I can't recall. Despite the limited amp pairing, I’ve decided to go ahead with the Lintons.
As for the amplifier, I’m considering something in the ₹2–3 lakh range, as another forum member suggested—though that purchase will likely happen at a later stage.
@prozkater Sorry I missed this thread earlier!
I’ve lived with the Lintons for about 2–3 years and have tried them with numerous amps. Here are my favorite pairings, in order of preference (not an exhaustive list of everything I’ve tried):
Willsenton R8 > Audiolab 7000a > First Watt F7 > @yogibear's EL84
As others have mentioned, pairing the Lintons with a warm amp can sometimes make the overall sound overly warm and a bit mushy. I’d recommend going for a more neutral-leaning amp instead—something that’s still musical but doesn’t overdo the warmth. Auditioning in your own room is essential, as the sound can differ significantly from a showroom experience.
I’d also avoid SMSL gear for this setup—they tend to sound a bit dry in the mids, and vocals can lack naturalness. Instead, consider the FiiO K11 R2R—a fantastic DAC that punches well above its price (beats most options in the ₹20–25k range).
For streaming and DAC duties, the Bluesound Node ICON is another solid pick, and if you go for the version with Dirac, it’ll elevate your setup even further.
Since you already have the 6000a, I’d skip the 7000a. I’ve owned both, and while the 7000a does offer more power—which helps open up the Lintons—it still retains a similar tonality overall.
My advice: get the speakers and start auditioning amps at home. Avoid blind buys—your ears and room are the best judges.
EL84 SE is a different animal.now... Now sits at my favourite spot. And also the new EL84 PP IT Coupled.
I had the opportunity to audition the Wharfedale Super Linton and Revival Audio Sprint 4 the day before yesterday at Watthifi audition room. While both were a clear step up from the Dali Oberon 5, the improvement was more marginal than I had hoped. That said, I really appreciated the voicing of the Wharfedale.
Unfortunately, auditioning amps at home isn't feasible in my location. I'll have to rely on user reviews and opinions to make an informed blind purchase.
Btw, has anyone had experience pairing the Rega Elex Mk4 or Arcam A15 with the Linton, with or without an external DAC?
Oberon 5 is a surprisingly amazing speaker. Well reviewed by owners and expert alike.
I have lived with Oberon 5 for a long time. A high quality EL34 PP amp with 40 odds watts with Oberon 5 together with a good streamer and DAC is very very difficult to beat combo, specially for a small space.
I had to completely change my set up and take a completely new direction to have any meaningful upgrade.
Any, congratulations on your Lintons.
lol, that's not surprising at all. Budget speakers circa 2016 and beyond levelled up tremendously and paired with a decent amp, are very capable.
I run a few accomplished and well-reviewed speakers, both by users and pros alike, and yet i find myself listening to my budget ones from time to time because they're not a huge step back but more importantly, they exhibit their character.
For example, my last switch-up of speakers in my main room was the DYnaudio Focus 160 (3000USD) from the Klipsch RP600M (600USD) and i immediately noted to myself that while the Dynaudio was more composed, nuanced and detailed in every which way, the Klipsch simply had more pizzaz and character.
Lol, that forum member is me and WattHifi is a 15 minute (8km) drive from my place - if you're still in Delhi, why don't you come over and listen to the Kinki Studio and hear what kind of an upgrade it offers over the range of amps you're looking at? PM me if you're still around these neck of the woods. You can listen to more speaker and amp combos than most showrooms 😄
Thank you for inviting me! Unfortunately, I have an upcoming surgery, but if my schedule allows, I'd love to visit and give it a listen.
