Cambridge Audio "One" - Any opinions?
Sumain
Hello All,
I am looking for a CD Player & Amplifier for my living room, to be paired with a good set of bookshelf speakers. (I'm thinking Tannoy mercury F1)
I came across this unit from Cambridge Audio while researching on the Internet.
It costs about 32K, and also has tuner and iPod dock included.
Please check out the link below:
One integrated CD player & DAB/FM 2.1 receiver system
Does anyone have any opinion about this unit?
Any alternatives that you would like to suggest?
Cheers and thanks in advance
Hi:
I think this is your second post on the same topic. Anyway, the CA is good, but you can also consider the DENON DM37DAB, which is fantastic too paired with a MA BR2.
Sumain
If you are a true stereo lisener than go for seprate Cd player and seprate Amp. This can come to your budget but it will be secondhand.
Hi mitul_mehta,
I would not know where to start looking for a second hand set. I am in Noida.
If I were to buy new, by how much would I have to stretch my budget?
Sumain:
Yes, separates always beats hands down the micros. Ok, a typical budget setup from the CA stable IMO would be...
CA 340A
CA 340C
F1/MS 902i/Diamond 9.1
... and you won't be dissapointed.
Sumain:
CA 340A
CA 340C
How much would the above setup cost? (Approx.)
I have a spare set of Bose 301 with stands. Can they be used with the above setup? I can then delay or avoid purchase of new speakers.
