aniruddha82
Any one have idea about good carpentry workshop in Pune?
I am looking for a workshop instead of getting speaker boxes built by a carpenter at my place because of the below reasons
1) Had bad experience with carpenter doing circle cutting, circle was not smooth as it was cut using a drill machine and not proper circular cutting tool.
2) Panels were not exactly equal there was difference of 1mm or so may be because there was not enough space or proper bench to hold plywood while cutting.
3) Edges were sharp, again may be due to lack of proper sanding tools.
4) I assume that workshop will have proper space and tools and skilled carpenters.
