CDp+DAC or DVDp+DAC
Dear Sir
I have compared , Via Coxial SPDIF, oppo 93, Pioneer DVD
Philips DVD, Marantz 5001 CD player
with a good DAC, the oppo out was best, followed by Marantz 5001
then a big gap then pioneer DVD and last Philips DVD
other things remaining same, the source does make a difference
the diff comes because of the way the data is transmitted at
player side and received in DAC, at the DAC end the shape of the pulse
gets affected, the rising edge becomes curved,sloped depending on
the coupling method, like capacitor coupling, transformer coupling etc
this has an effect on sound quality, there is definitely audible diff
depending on the player, bit correction, laser servo and lots on variables
can be there in addition to shape distortion in data pulses
to change the sound, I felt safer to use Foobar ASIO in PC to DAC
via USB
Robert Bose
Thanks for the very informative reply regeHA. I am downloading Bug Head now and will research everything you mention.
Cheers.
I am downloading Bug Head now and will research .
Cheers.
Few of my friends were not ready to give a try to Bughead after seeing the interface and they were actually searching for good DAC to upgrade. After I convinced them to give bughead a try, later all of them upgraded their PC & Laptop while DAC remain unchanged.
Go with a Raspberry Pi for source/transport and spend all the money you can on the best DAC. The SQ will be unbeatable.
Later on you can use a PC with HQP and use the Pi as NAA... some of us are doing that and finding it even more of an improvement.
If I'm understanding this correctly... a PC with HQP will stream processed audio to a Pi-as-NAA? Over wi-fi?
And the pi will then feed digital audio into a DAC? How will this connection be made?
USB or Toslink (need Pi addon board from HiFiBerry or IQAudio).
The newer devices like microRendu are becoming extremely popular as NAA devices - ethernet input, USB output to DAC.
The PC can be on the network in another room and transmitting data via ethernet or even wireless.
