Choice of Fabric for DIY projector screen
tomonpublic
Hi FMs,
Decided to go for DIY projector screen as per Elango and other FM's suggestions.
Can you please clarify my below doubts?
1. I am constructing a screen which can be used on both day and night. So based on the suggestions, I decided to go for Silver Grey colour. Is this a wise choice?
2. Which kind of fabric should I use for the screen? I am least bothered about the acoustic transparent. Because I am planning to mount the screen directly on the wall. No speakers behind.
3. Since i am attaching the screen directly to the wall, i need a fabric which do not reflect the light back from the wall. Also reflective light on the adjacent walls should be minimized. In this case, what kind of fabric should i consider? Thick Single fabric or multiple layers (grey on top of black)?
4. Most importantly the fabric should be a cost effective one.
Note: I cannot paint my wall with grey due to several restrictions.
Recently, a FM using dark grey over black spandex and the said the results were good..
Eventhough you don't need the screen to be AT, Lycra spandex is the one aval locally and very much affordable..Am not aware on other fabric screen material that can be used, please wait for other FM to pitch in..
When i tried doing the AT screen, i was suggested by FM @manoj.p to add a back layer (black) behind the white screen to prevent light loss & it did.. You could also do the same..
You may also consider a map type screen (Vinyl based) which you can directly nail to the wall around the 4 corners.. They shouldn't be too expensive compared over DIY fabric screen's effort - https://www.amazon.in/Luzon-Dzire-P...016&sr=8-9&keywords=map+type+projector+screen
One more link - https://www.amazon.in/ELCOR-Project...=8-31&keywords=map+type+projector+screen&th=1
I have done this excercise already. A dark grey screen did the magic.
https://www.hifivision.com/threads/...arent-dark-grey-diy-screen.69579/#post-765489
Just see my above thread.
Getting Dark grey is the tough task I could manage.
Don' t go for Pattak or Kongu wood they are all heavy and stapling the cloth is difficult. Go for the woo which is used for making boxes, it's lite in weight easy to work with and for hanging. The screen material is Spandex (Lycra fine) and the GSM should be 250. Do not stretch the cloth beyond 10-15% max otherwise you will have light leakage. The total cost incurred by me was 6K.
The wood to go for is pine wood. Its light and used for packing material and easy to staple.
For the screen material, you can reach out to the cinema screen providers. I had contacted one, but he was not interested in outstation buyers as he was based out of Chennai.
