Chord Carnival silverscreen speaker cable in Bangalore?
vraned
Folks,
Where can I buy the Chord Carnival silverscreen speaker cable in Bangalore, and how much might it cost? I have Kef Q300s and believe it can bring out good mid-range from the Q's. Would also appreciate if you could share your experience with it...
i bought a few meters from profx, mg road - a couple of months back. sounds good - but imo my monster biwire cable seems better.
I got th is chord cable @330/- per mtr unterminated. You guys are paying way too much.
--G0bble
i just swapped some cheapie monster cables to carnival silverscreen and the difference was night and day!!! the sound just leapt up!!!
Strange .. the chord SS did nothing spectcular in my setup ... its just lying about like a snake ... :( Is yours factory terminated?
--G0bble
The change in sound quality is mostly heard (level matched AB comparison) in the following cases:
1. Your previous cables were really bad (meaning high resistance especially long runs of thin wire).
2. All the components in your setup are really good and very revealing (a rare combination because mostly the best upgrades that can feel like night and day are speakers and source material).
I found very good improvement with chord carnival when compared to stackfine cables which I bought at rs. 100 pm. More detailed for sure.
Sent from my GT-I9001 using Tapatalk
Nandac, where did you buy the silverscreen and how much did they cost you?
profx in mg road. not sure about the rate because i bought it a few months back. i think like 12 meters for like 4k or something like that.
