Confused!! NEED HELP
jk_chaos
Trivandrum,Kerala
Guys, I own a denon pma 510 and a marantz cd 6002. Now I've got an acer emachine e725 laptop which I wana use as a source. I've got loads of my mp3s stored here...Now how do i go about it? Now I am using a DAC interconnect that connects the headphone out from my laptop to the LINE IN in my amp. I am not happy with the sound this way. So what do I do to get things changed?
One problem I am having is the laptop is a low end one with a USB out and a headphone out.. No optical/co axial stuff..
HELP ME PLEASEE
HELP ME PLEASEE
USB out..?? didn't get that..
Which DAC u r using.. der r lot of threads regarding DACs in this forum.. may be changing DAC may result in good quality sound..
Thanks for the reply sagar
I dont use a DAC.. Just that the lap top has a couple of USB outputs and a headphone output. Nothing else..
As for me I connect the headphone out to the amp
HELP ME PLEASEE
You can buy a usb dac or an external sound card with optical or co-axial output.
You can get a USB DAC.. search for DACs in the forum.. u'll get lot of options.. it'll take input from USB and will give you 2.0/2.1/5.1 out which you can use as input to ur AVR..
You can get a USB DAC.. search for DACs in the forum.. u'll get lot of options.. it'll take input from headphone out and will give you 2.0/2.1/5.1 out which you can use as input to ur AVR..
USB DACS connect directly to the usb port of the computer, not to the headphone out.
@jk_chaos - what is your budget for a dac or external sound card? Does your amp has optical or coaxial input?
ooops.... my bad.. wanted to type usb.. :lol: Corrected the post..
I am sure the laptop would have wifi capabilities. How about using a streamer like squeezebox duet or squeezebox touch or sonos.
Your budget would define the options.
@ baiju - The amp has no optical or co axial input!!
Well yes the laptop does have wifi options and I have been reading a bit on the squeezebox. Never got that idea clearly.. Would someone mind explaining??
How a lossy format like MP3 could possibly sound great even using an external DAC, in fact it would sound more pathetic on good amp/speaker's setup. Have you tried with source like ACD ?
Regards ...
HELP ME PLEASEE
DAC way
from your pc's usb > usb input of dac > output of dac > your amplifier
Squeezebox
Squeezebox software on your pc > wifi > squeezebox in > squeezebox output > amp
Try using a HRT music streamer- you can read the review in What hifi. It takes your USB out from the laptop and can give a stereo out to your amp. You can check the prices on Amazon- shouldnt be more than 6k
Happy listening
