Fantastic
I mentioned long ago about skin depth and gave some figures.
Capt. Rajesh asked for details about thicker wire which I did not have that time and as usual , as the thread gets older it gets lost !
I lost the link to the original web page but accidentally came across another one today which mentions all wire sizes. You can take your pick !
American Wire Gauge table and AWG Electrical Current Load Limits with skin depth frequencies and wire breaking strength
It would be interesting ( an inexpensive !) to experiment with thinner enamelled wire in groups ( each less than 1mm dia) as speaker wire.
Possibly use less than 1mm max dia for woofer/mid and maybe 0.5 mm dia for the tweeters. Calculate the no of wires needed to use in parallel to achieve the resistance you want.
For example to get 4 square mm ( about AWG 11) you can use 8 wires of 20 guage (SWG) in parallel. These will be insulated from each other and so 'possibly' is better than a bunch of smaller wires uninsulated from each other. Rather like Litz wire but on a bigger scale !
Maybe same could be done for the tweeter wires too with even thinner wire.
Bundle them separately ( + and - leads) in teflon tubing and put the two resulting cables in a braided nylon tube ( available ) with heat shrink tubing at the ends and voila you have a $1000+ cable !
Anyone interested in trying it out ?
By the way I had also mentioned about using single core silver plated copper wire with teflon coating as a line level interconnect. I bought some 30 SWG wire ( 0.32mm) and used 3 wires per cable twisted about 3 or 4 times per inch. Decent RCA plugs at the ends.
How did it sound ? Like a very nice cable ! Nothing lost. Good HF and good all the way through ! But it does pick up hum even though the third wire is earthed at one end. But I must admit the situation was not ideal. There were a couple of open ( powered up ) transformers fairly nearby. But then again the hum was very low and only audible when you put your ear near the speakers. It's very nice ,so I continue to use it in place of the original cable. No time to do exhaustive tests but it was money well spent !
Total cost : 4 RCA's 400/- 1.5 meter cable x6 lengths at 9mx6/- = 54/- = Rs454/- + labour plus transport !
That works out to about a minimum of least Rs 2500/- !!
Suggest you try it out .
