Copy from TataSky+ to CD/DVD (?)
tian
Pune
I have recorded a program on my Tata Sky+ which I want to copy to a CD/DVD. However, I am not sure how to go about doing this. Can anyone suggest how I can do this.
In tata sky plus the programs are recorded on the memory and its in incripted form so there is no way through which you could transfer that onto a cd or dvd.
This should work but have not tried.
Connection needed.
TS+ to AVR via Analog AV in
AVR to VCR / DVD Recorder via Analog AV out
When you play TS+ recorded program, it can be simultaneously recorded in the VCR/DVD-R. However, you must play the entire program. There is no direct transfer method.
I record from Dishtv with my PC.I have installed TVtuner card which has AV input.I connect Dishtv AV output to AV input of TVtuner> play the program & record it at same time.Various formats available from DVD to iPod too.
You can try same way.Recorded Q is good & stereo recording is possible...
(avertv 007 FM plus go card)
