DAC for a HTiB DVD player
The DVD player and amplifier are in one unit and wired internally.
Even if you want to use the unit as a DVD player, and connect to an external amplifier, the unit does not seem to have a digital out. All I can see from the specs are S-video output, composite video output; component-video output. Unless the unit supports a coaxial or optical digital out, you may not be able to connect an external DAC.
Please look at the unit carefully and see if it has a digital out.
what are you looking to improve in the sound? The clarity or dynamics? If it is clarity, then the DAC may not help otherwise if it is dynamics it may help a bit. I personally think it is overkill to use a DAC with HTiBs. Other components in your system should be at par to get better clarity and dynamics including your speakers, input source, transport (HTiB) in this case.
Hold off on spending money and invest in something better down the road.
I have a Sony HTiB DVD Home threatre player. It has jacks directly for connecting speakers. Is it possible to use a DAC to improve its sound ??
The model is Sony DAV DZ 120K
Sony DAV-DZ120K home theater system Overview - Other home video products - CNET Asia
If you want to improve SQ of music,then another option is ,buy cheap mp3/DVDp ,add DAC & input to your existing HTib via Aux in.This will make less use of your inbuilt DVDp & you can enjoy it to longer period.
new DVDP >DAC >HTib
You can also buy a good CDp & input to HTib.Mar 6002 can play mp3/WMA too.
CDp> HTib
