DAC with USB and digital/optical
Shivam
Uttarakhand
I am looking for a good DAC with USB and one digital or optical input. I need it to be able to handle 24/192 files over USB too so that I can use it with my laptop.
Budget is not more than 50K though cheaper the better. Any suggestions ?
Shivam, if you want 24bit 192kHz support over usb not sure if there are any dac's with in your budget presently.
Workaround would be buy any dac of your choice and use M2Tech hiface with it.
You can get the M2tech young dac for 58k. It has everything you need. It is very decently priced in India considering international prices. Mail ganeshATtridentmalaysiaDOTcom.
I am in the look out for a 24/192 around 50k. And I think using hiface interface will be the best vfm.
The options could be one of:
1) Musical Fidelity M1 DAC
2) Music Hall DAC25.3
3) Rega DAC
4) Benchmark DAC (or the more expensive DAC-USB)
Although I have no idea where to audition these in India
