Dali Lektor 2
I believe Dali is changing their distributor from Sight and Sound to Kripaindia, hence I was informed there might be some initial supply shortages.
Murali Sir, thanks for the info. I am in Kolkata and if i buy I need to order them through courier. How credible is the shop you have mentioned here.
Hi TW,
I have purchased MS Aviano-2 from Cressida in January-2011, and another forum member had purchased the same model a couple of days ago from them. Cressida is a dealer for Dali too, and their service is good. I also suggest that you see an ad placed by Musicmaya for Dali Ikon-1 in For sale section. But I don't feel it safe to courier the speakers, as there is always chances of damage to the drivers unless they are packed and handled properly.
N.Murali
but aren't these speakers shipped from phoren to India? In the same packing, it should be fine to be delivered, if purchased directly from the dealer?
Hi anm,
Though the Packaging is taken care of by the manufacturer, the handling part by the Courier needs serious thought, unless it is done by a reputed company. Also the price advantage derived may be offset by the courier costs.
Just my thought.
N.Murali
