CRC error indicates data corruption. This could happen due to various reasons:
1.>Bad HDD
The Hard Disk is gone for a toss, and has developed bad sectors. This can be confirmed if you hook up the HDD to another system, and get the same errors on copying files from the HDD
2.>Bad RAM
The RAM has become flaky. It also happens that sometimes your Motherboard does not play nice with the RAM, and you'd get this kind of errors. You could test the RAM with memtest86+. Google for it, and download. If it gets stuck performing checks, or detects errors during checks, you have nailed the culprit.
3.>Bad PSU
If your PSU is not able to supply sufficient juice, or is not able to regulate the voltages/currents within the specified tolerances for ATX specs, then you'd see this kind of behaviour. In my experience, the PSU that comes along with the cabinet is crap, and gets flaky after 1-2 years of usage. The only way to confirm would be to hook your system to another PSU.
