Denon 1908 front panel locked. How to unlock?
Sumain
Dear All,
My Denon 1908 front panel has got locked on its own. If I try to operate any knob other than power-on or volume, it does'nt work and I get the message "Front Panel Locked" on the display.
It is fully operational through the remote though. Except for Speaker Set A/B switching, which works only from the front panel.
I tried to reset the system with the procedure described in the manual. Worked once, then the system got locked again, and now even the reset sequence does not work.
Please help. I am in Noida. Can I show the system to someone?
Best regards
Sumain
