The AVR-1611 is an A/V receiver with HDMI version 1.4 that can be connected to TVs and other devices such as Blu-ray disc players, game consoles, and set-top boxes, that support 3D video. Of course, it also supports HD Audio formats such as Dolby TrueHD and DTS-HD Master Audio to give you the powerful, dynamic surround sound you expect with the amazing 3D video images youre watching. In addition, the AVR-1611 provides a wealth of features that you would want an A/V receiver to have, including HDMI conversion when connected to a TV via a single HDMI cable and a different type of video signal is being input to the AVR-1611, convenient on-screen displays, and easy operation.
Features
- Featuring 3D pass-through technology
- Supports HDMI 1.4 with 3D, Audio Return Channel, Deep Color, x.v.Color, Auto Lipsync and HDMI control function
- 4 x HDMI in / 1 x HDMI out (Repeater)
- Newly developed pre memory remote control handset with Glo-Key
- Remote Setup Guidance
- One-cable HD solution
- Supports HDMI 1.4 with Audio Return Channel
- All sources are up-converted to HDMI
- 4 x HDMI in / 1 x HDMI out with On-Screen Display
- State-of-the-art Denon Solutions for Maximising Content Quality
- Fully discrete, identical quality and power for all 5 channels (110 W x 5ch)
- Stable power supply for high-quality sound and picture playback
- High definition audio support, Dolby TrueHD and DTS-HD Master Audio
- Supports Dolby Pro Logic IIz processing
- All video-sources are up-converted to HDMI
- Connectivity & Future-ready Expandability
- Dock connectivity for iPod and network streaming
- Ease-of-Use
- On-Screen Display
- Audyssey Dynamic Volume, for real-time volume adjustment
- Audyssey MultEQ and Auto Setup: Tower type microphone for more accurate measuring / Up to six measurement points / High level resolution filters for satellite speakers and also subwoofer
Others
Lower power consumption at stand-by 0.1 W (Standby)
Power amp construction discrete
Large Aluminium Extruded Heatsink (sound-optimised)
Bandwidth 10 Hz - 100 kHz
Sound Formats
Dolby TrueHD
Dolby Digital Plus
Dolby Digital-Decoder
Dolby Digital EX
Dolby Pro Logic II
96-kHz Processing (analogue / PCM)
Dolby Pro Logic IIx
Dolby Pro Logic IIz
DTS-HD
DTS-Decoder
DTS-ES Discrete/Matrix 6.1 /
DTS Neo:6 Cinema & DTS-Neo:6 Music /
96-kHz Processing
DTS 96/24
DSP
DSP 32-Bit Floating point-DSP
3rd Generation SHARC ADSP-21367
Cinema Equalizer
Virtual-Surround (Headphones/Speaker)
DSP programs 7
Multichannel Stereo 5CH-/6CH-/7CH-Stereo
Digital Circuit
D/A converter 24-bit / 192-kHz
A/D converter 24-bit / 96-kHz
Digital Interface Receiver (DIR) 24-bit / 192-kHz
Auto Setup
Detection of connected speakers
Speaker phase check (absolute Phase)
Detection speaker size (large/small)
Recognition of optimal crossover frequency
each speaker individually
Automatic time delay adjustment (0,01 Metre increments)
Automatic level adjustment (0,5 dB increments)
Accurate microphone DM-A409 (included)
custom made by Audio-Technica
Auto Room EQ
Operating mode Audyssey MultEQ with Advanced Low Frequency Correction (ALFC)
Measuring Algorithm Audyssey MultEQ
Optimisation/EQ curve memory Audyssey: MultEQ Algorithms
Choice of EQ curves without re-measurement of the system (Audyssey, Audyssey Flat, Audyssey Byp. Front, Manual)
Manually adjustable graphic EQ 9 Band
every speaker individually
Direct Mode with/without EQ
EQ curves assignable to surround modes
Copy function for measured EQ curves into manual graphic EQ
More info:
Click Here
