Denon receiver repair referral in Bangalore
Dipankar Paul
Hi friends,
I am new to this forum.
Can anyone refer me for a good technician who can repair my old Denon 1509 AV receiver in Bangalore.
Its going to standby mode moment you turned on and power/standby light blinking red.
Thanks,
Dipankar
I just gave a stereo amp for repair to HiTech service point koramangala. Behind bethany school. Saw a lot of receivers,amps and turntables for repair there
/QUOTE]
For what it's worth,
I've had this same problem with my Denon for years every monsoon.
Thinking that it is the high humidity in Mumbai causing the problem I used the blower end of my vacuum cleaner to warm up the unit and dry out any condensation inside.
Worked like a charm every year till I stopped using the home theatre and the buttons of the front panel wouldn't respond.
You could give this a try before opening it up
If anyone a quick fix for the front panel micro switches please do respond
SDK
