rikhav
- Joined
- Mar 27, 2008
- Messages
- 2,675
- Points
- 113
But IMO it does not matter for DIY builders as they are designing only for the measured driver parameter. Hence even if the drivers are not meeting the published QC that does not mean its junk. You can still build your own box with the measured parameters. If you rely on the published parameters then you are asking for trouble and there will be endless tweaks without any achievement.
Purchasing locally for a production run is ruled out as these drivers cannot follow a set design pattern and need to be voiced individually which is impossible for commercial production.
Hi hari
Atleast a pair should have matched parameters
I think even for DIY that is important
