I am hoping to buy a used (fairly new) pair of Audio Nirvana Super Ferrite 8 inch speakers for Rs 18000 /-
What do you guys think ? Is the price right and should I buy them at this price.
Please share your opinions here.
Shaan what do you think of this ? Should I buy this speaker ?
hi yogibear...Great thinking ! You can always change just the mounting laminate baffle and experiment with different drivers. Something similar to my upcoming build.
Many of the drivers available locally are quite good for DIY projects. Often DIYers think that putting a system with Boutique drivers is going to get them a good system. The reality is far from it. The local drivers if used 'properly' will give the most bang for the buck.
I ve measured quite a few OEM drivers and found them to be very consistent in T/S parameters as well as frequency response.
This 8" driver seems a good one, no doubt its been around for a long time.
BTW, do you think the driver lacks any highs? I am contemplating a project with this driver.
Thank you yogibearA volume larger than required should always work and you experiment with different drivers of similar sizes and jobs. And you can also play with placements and even going from sealed to ported and evev diffferent port dimensions for the same driver. For example even more than one port.
Saves you the effort and money of trying different boxes for same or even different but similar drivers.
Also check Iwai.com They have some very nice drivers.
Car sub drivers are very good. One can make a 12" sub with dual 12" PR (DIY PR with 12 cones and baskets) , paired with 200watts it would be a killerAnd if I can get some good drivers in local Hyderabad market, it will be great to experiment.
I'm getting used to the software one at a time. Sooner or later i will surely try BastaWhy not use "Basta" to simulate ? Will help you save a lot of effort, money and time. Will also give you a great idea what one single box with different baffles or / and different drivers will do.
Its one of the most accurate software and highly recommended and even used by MJK himself. Well respected audio DIY master crafter and a great gentleman too !
