Dont throw burn fail dvd disks
kaushik
Some time you see "an error occurred while burning..." dvds
Those may be burnt with low speed in a next retry...
what i do :
use cd burner XP>datadisc
add the data
burn>'letme choose...'
speed=4x,simulate burn process
After burn process it will ask
do you need files tobe burnt to disk
select "no"
exit cdburner xp
see files are burnt nicely .Enjoy.:clapping:
For this trick to work select the disks that indicate burning fail at the beginning of the burning process.
Half burnt disks may not be suitable.
It works for me when when i see burning failed,in details there is " powerCalibrationError " with cheap dvds, some times even in Verbatrim,moser baers.
I am using VistaHP.
I have found that if burn fails,DVD can be written in Nero too ,but space blank shown on DVD is only upto OR less than 30%.
Do these tricks work with Dual Layer DVDs?
8/10 times the burn process fails with me, when using DVD+R DL :(
regards,
Nitin.
check it out your self,
Some more links of interest related to CD/DVD:
Here is a tip to do CD resurfacing with Brasso metal Polish.So that the scratched out CDs play again .
Instead of creating a thread i am adding here.
Re-surfacing CDs so they work again.
Mod Cannon pixma for printing directly on cd/DVD:http://www.instructables.com/id/Modify-Canon-Pixma-Printer-to-Print-on-CDs--DVDs/
