Sorry, if this is the wrong thread. This post is about file storage, thus I thought it is applicable here. If the forum administrators think that it should be posted in another thread, please do move it.
I wanted to see if I could further optimize sound quality by making changes to where/how my music files are stored.
I use an Oppo-103 as the digital source/transport/renderer/streamer.
The Oppo is quite heavily modified (upgraded power supply, fuses, internal cabling, footers, furutech NCF power inlet etc.), so it functions as a pretty good sounding transport - enough to hear changes made by tweaks. It feeds a Rega Dac-R via coaxial spdif.
- Scenario 1: files stored on a regular Transcend 1TB external hard disk, connected to the Oppo via USB (controlled using the Oppo app on my android phone).
- Scenario 2: files stored on a Seagate surveillance 4TB HDD, in an aluminium external hard drive enclosure (photos below). Connected to the Oppo via USB (controlled using the Oppo app on my android phone). The hard drive enclosure is externally powered with a stock 12V wall wart. So the hard drive is not "bus powered".
- Scenario 3: files stored on the same Seagate surveillance 4TB HDD, in a Synology NAS. Connected to the Oppo over the ethernet network. Oppo as "streamer", "pulling" files from the NAS server (controlled using the Oppo app on my android phone)
- Scenario 4: Same as Scenario 3. Oppo as "renderer"i.e. files "pushed" to the Oppo from the NAS (using BubbleUpnp control app on my android phone)
My home ethernet network is not optimized, but it is wired and it is stable. There is a 24-port netgear switch.
I've been listening to the same music files for a while now, and am quite familiar with how they sound in my system.
Scenario 2 is the best sounding. The sound is more effortless, more in my room. More clarity, better separation in the soundstage. I know - audiophile cliches
, but I really do think the sound is the best with Scenario 2.
Scenario 1 is next best.
Scenario 3 and 4 sound different to each other, implying that method of file transfer (push vs pull) also makes a difference.
This was not a controlled scientific experiment. But just a guy tweaking! The results could be due to lots of reasons, and of-course there are so many different variables.
But I do think this is interesting, and worth noting that how you store your files, makes a difference. Small changes do matter. You could have an expensive digital front end, but you still can get better sound by tweaking how you store your files.
Look forward to hearing what others have experienced in this area?
Now, my audiophile brain wants to take this further
- Upgrade the USB cable that connects the external hard drive to the Oppo. Am thinking of the solid core Neotech USB from Ghent Audio with JSSG360 shielding.
- Upgrade the power supply to the hard drive enclosure (either a 12V li-ion battery bank, or an LPS)
Photos of the hard drive enclosure used in Scenario 2:
