Factory service code for VU pixelight HDR 2019 model
ksarvind123
Mawana
nearly a month ago I have bought a new VU pixelight HDR 43 inch 4k TV but colour purity is not accurate therefore I tried calibrate it. It has color tuner option in it's menu but it doesn't work. I could only adjusted white level but when I view reguler pictures then it shows a unnatural redness in picture and that can't be removed. If anybody can tell me the service menu codes
Searching on google.com I have realised that Vu TV is rebranding Chinese Hisense TV. The mother board is being used buy other TV brand in India also like BPL loyed Akai etc.
I also found the answer of my question.
Hisense Service Menu Instructions
Method 1
  1. Hit menu on the remote
  2. Tap right to enter the full menu
  3. Scroll down to sound
  4. Tap right and select Advanced Audio Settings
  5. Scroll down and highlight the Balance slider, make sure it is on 0
  6. Enter 1969 on your remote
  7. The menu will disappear and a green "M" will appear at the top left
  8. Hit menu on the remote, this time a service menu will appear
