floorstanders a cut above monitor rs6
so what are the other floorstander options which can be considered as a cut above the monitor rs6?.
Dali Ikon 6 ..Mordaunt Short Mezzo 6
I'd add the Focal Chorus 726 series (826/836 a cut above) in the same price range as the Dali Ikon 7 and also the KEF Q500/700 and Triangle Antal-EX. THese speakers all sound very different so please listen before you buy preferably with your own music and electronics and in your own room (or atleast a room similar to yours).
BTW the RS6 has been discontinued and the RX6 is the new model..just in case you did not know.
Harbeths...Tannoy dual concentric single driver speakers
These are not a cut about. They are 2-3-4 cuts above. :ohyeah:
I did a lot of research before buying the RS6....When partnered with equipment like Nad, Musical Fidelity, Arcam, Parasound, the RS6 sounded brilliant. So as someone else has rightly said, it is a matter of synergy.
Finally someone who treats the system as a sum of parts. Well done. Shanti/Bhagwan would be proud. :clapping:
