Floorstanding Speakers - Help Needed.
vikramdeo
Hello All,
I have Purchased a Yamaha RX-V 461 A/V Receiver. I am now looking for good Floor-standing speaker pair to compliment this baby. Can somebody advise me on the same. By bugget is around 18000 INR.
Vikram Deo
[email protected]
You should audition the Wharfedale Diamond 8.4 and Mordaunt-Short 914i speakers. Polk Monitors are also within your budget but I have not heard them.
Thanks Particle man. By the way I am in Bangalore, so is it possible for you to tell me about any dealer based in Bangalore for the speakers you have mentioned?
Vikram Deo
Wharfedale
Vector Projection Systems
97,Brigade Road,After St Joseph College Of Commerce
Brigade Road, Bangalore, 560025
+91 80 25543287
+91 80 25543587
+91 80 41128686
Mordaunt-Short
Audio Planet (behind BDA complex Koramangala)
Phone 25523126, 9845019192.
Polk Monitors
You can get Monitor 50 for 20K/pair
PROFX - the home theatre specialists
The Sonodyne Sonus 2605 are also around 20K
Check out their listening room in Forum Mall.
How much did you pay for the Yamaha and where in Bangalore?
~dich
Hello,
Thanks for the detailed information. I will be paying 18K for that Yamaha receiver and my friend will be getting it for me from a Delhi Yamaha Dealer with Warranty. I was not able to find someone for Yamaha in Bangalore. I am interested in Yamaha as they are good for movies. If you have inputs on these then do let me know.
Rgds,
Vikram Deo
Vikram,
Speakers from Jamo
You can also visit Garuda mall in Bangalore. Jamo showroom(2nd floor) is there. Thay have excellent budgetry floostanding speakers. I myself is one of the proud customer.
Regds,
Shawn
Hello,
Rgds,
Vikram Deo
Hi Vikram,
Check out the NS555's + NSP pkg I have posted in the classifieds - they are a good match for the Yamaha 461. I am now using NS 777's.
Viki
Hi Viki,
Where did you buy the Yamaha Speakers? How is the Quality when compared to Elac/B&W Speakers?
Robin..
bought them from the yamaha dealer in pune. I have'nt heard Elac, but I definitely preferred them to a pair of B&W's that I had auditioned before I bought my Yammies. Could have been the amp they were using, though. Also, the B&W's seemed expensive for the size and spec.
Viki
