focal 826vw or b&w 684 or tannoy revolution DC6t se or b&w cm9
subabu2002
ERODE , tamil nadu
hi friends ,
i am looking for floor standing speakers and shortlisted the titled speakers..
focal 826vw or 816vw
b&w 684
b&w cm9
among those which one will be best for both music and movies..
i dont want harsh sounds..
any opinions?
thanks
suresh babu
thank you CSD... KANT,
my room size will be 16*17 ft..
planning to use it with integra pre/power combo for multichannel and marantz pm6004 for stereo.
-suresh babu
A 6004 would struggle to drive these big 'uns. Consider bookshelves from the same series or a beefier stereo amplifier.
IMO, 6004 will not do the speakers justice and not drive them to their potential. I would suggest splitting the total budget between speakers and amp on equal terms. On speakers front, I would suggest you also look at MA RX6 in the similar price range.
6004 will not drive any of the speakers you mentioned.
There is a 8003 on sale in the forum for the same price. Better sound and power. Try that.
The B&Ws are definitely to be considered from the list...better sounding for music and movies.....depending on your budget and spacing...you can decide between the 684 or CM9.
You should look at using a Marantz AVR or amp as the company has been in existence over 50 years and have focused on delivering MUSIC depth and warmth in the products as PRIORITY ONE! I am a happy Marantz user.
All the best...hope this helps.
