full hd mitsibushi hc 4000 with coopa hd media player
abhirag
BSR
dear all
I have attached coopa media player with normal hdmi cable 10m length 1500rs with mitsibushi hc4000 full hd projector.
Player and projector is working properly when selected to 1080i but if i tried to select 1080p on my player picture doesnot remain stable keep going and coming.if selected back to 1080i it works properly.
Help me out friends about this whether its a problem with cable. Player or projecter.
Use a short cable and test the video. If it works fine then the problem is with the cable. For large distances good quality cable is essential.
You ure Coopa player? That's interesting. I thought I am the only human using this brand :-)
Now regarding your problem, as mentioned by Baijuxavior, try a different cable. A better one as 10m is quite long.
Hello members!
Iam also one the User of Bluetimes Coopa MP....
Regarding the problem i also suggest the same.
Murali.
i agree with baiju that 10m or above u need good HDMI cable . Try with Small length cable and revert or buy a good quality cable of 10m
Also I remember seeing that some cables only support 1080i and dont support 1080p. Could that be the case? I remember seeing it on one model of MX 10 meter HDMI cable pack.
Thanx,you are right,I tried with small cable it worked.So I am going for good brand cable.
Facing another problem with UPS.My Mitsubishi HC4000 is not working on offline UPS of 800 va.I tred 3 different brands of diff. wattage.It got tripped during powercut.
Suggest me wat to do.
regards
regards
somewhere in the forum threads(audo video components section) I read that the offlineUPS changeover to battery is 21 ms approx and for onlineUPS it is much shorter ie approx 8 ms.
Probably your HC 4000 might be switching off faster than 21 ms.
