This cable would be used between my laptop and the LED TV. I think most of the guys here are suggesting based on whether I will connect a digital media player or DVD player.
So if I'm trying to connect my laptop to the TV which cable should I go for? Distance should not be more than 3 meters.
Discarding every once opinion, return China Made cable and bought Belkin 1.8m HDMI cable for 600.
Verdict:
No Difference in PQ as well as SQ
TV was showing 576i because of media player setting. That I able to correct it out.
I told you before you will not get any difference in PQ using expensive of china made cable. Good to know you found the correct resolution settings. I was wondering why you are playing the media through your laptop? You don't have USB in your TV?
I see lot's of them listed between Rs 100-Rs 250.
U have any online links?Go for cheap one, china made![]()
Links please? I see lots of them out thereIn ebay.in you should be able to get for 200?
Links please if possible!I bought one for 150. don't find any problem in picture Quality.
You are getting 576i because it is the resolution set by your player. These cheap cables will handle 1080p with ease. Which player are you using?
Buy a branded cable if your player and TV are separated by a large distance like 15 feet. For 2 - 3 meters these cables will work fine.
hdmi cable | eBay
I have a DVD player, I want to upscale the output to HD using HDMI cable. Which cable should I go for HDMI 1.3b from ebay.in is costing around 150 rupees. The LG home theatre that I have is HT502 that claims to convert DVD to 1080i quality.
Which player are you using? Have you adjusted HDMI settings in display?
