andy78
Guys where can I get cheapest HDMI 1.4 cable. I got one HDMI 1.3 for Rs 149 from ebay. Any links?
I have a general question here.
Though I know there are 2 different kind of HDMI cables: 1.3 and 1.4/1.4(A) ; but I have not seen any HDMI cable explicitly mentioning as 1.3/1.4/1.4(A) on the cable itself or in its package specification. Instead, there are few terms mentioned such as "High Speed HDMI Cable" or 'HIGh Speed with 3D" or "3D with Ethernet" or simply "HDMI cable". Sometime I saw 'Gold Plated High Speed HDMI".
Why isn't there any direct HDMI specification on cables which says it's 1.3 HDMI cable and the other one is 1.4 HDMI cable ????
Hope you understand what I'm trying to say !
why do you need 1.4? There is hardly any content for supporting its resolution or the 3D format. All the other new features such as Audio return from TV to AVR etc. will come in probably 2 future generations of TV.
The only advantage I see now is that you can ethernet via HDMI
The pack or box will always specify 1.4 or 1.3, even on ebay if you look in the description it will always tell you 1.4 / 1.3. Most regular HDMI cables sold are 1.3 unless otherwise specified as 1.4
I read something that would answer your question in the below link.
HDMI
There it's mentioned that companies shouldn't be mentioning 1.3 or 1.4. in the specs.
Thanks for your answers.
@Aakash: To be honest, I have never seen packaging mentioning as 1.3/1.4. On online portal, they have to mention it as 1.3 or 1.4 to sell the item. But in reality, when you get the package...you may not see original packaging mentioning as 1.3 or 1.4.
I saw the Wiki page and it seems a sort of HDMI protocol that companies are not mentioning HDMI version directly on it.
Still curious, why so ?
Bro, my primary purpose here is to connect TV to the AVR to get the Audio out of TV using ARC. I tried current HDMI Cable and it's not working. Onkyo guy suggested that I need to replace HDMI 1.3 with 1.4 ver.I think you are over complicating things here. For 5.1 surround, connect your STB to the AVR instead of the TV with an optical or digital coax cable. For pic, connect your STB to your TV via HDMI or your AVR to TV via HDMI. You are done!
That's not a stupid question at all . Yes both my AVR and TV are ARC Enabled.HDMI cables are High Speed & Standard and have nothing to do with version numbers.
You may try this - Belkin High Speed HDMI Cable with Full HD Support | eBay
btw - stupid question - I hope you have ARC enabled in both AVR & the TV.
Ok guys finally got MX HDMI 1.4 cable for Rs 350 and it's working like marvel.
Recently i bought a HDMI 1.4v cable 25 feet from ebay.in. my optoma hd20 arrived yesterday. when connected to himedia player the cable was not detected. when i connected it to my tatasky hd settup box and to my sony lcd, there was no problem. please guide me.
