Help in speaker positioning and acoustics treatment
You can do that on the left hand side corner of the REW screen once you take the measurements.. Just rename the curve in the small window..
Do you feel bass in the room?..
There seems to be a peak between at 55Hz and few more above 100Hz - 200Hz.. For taming the 100-200Hz, you can add broadband absorption in the room before EQing with Dirac on the AVR..
You have plan of adding subs?..
Bass is there but not too much.
I will try to add broad band absorption panels and then only will do room correction using Dirac..
AS of now no plans to add sub. May be later, a dual sealed sub.
