Help troubleshooting Elekit TU-8500 preamp
Hello all,
I am new here so , this might be a question that has already been asked. I just finished an Elekit TU8500 and I have an issue. One of the channels has a hum (probably 60 cycle) If I touch one of the ground screws in the cabinet, the noise backs off a lot so, it appears that I have grounding problem so something like that. Has anybody got a suggestion on fixing this problem?
regards
Hello all,
regards
I am assuming your chassis is expected to be connected to the earth wire on the 3pin socket.
have you checked / getting continuity from the chassis and the earth plug pin ?
Thanks for the idea, I haven't checked that yet. The cord has only a 2 prong plug on it so maybe I'll try a 3 prong as well.
At the end it was a faulty resistor that leads to VCC. All Bridge rectifiers were working fine. I will post an update after I'll receive the new resistor
Hi, was it r59 resistor that was damaged. Did you figure it out using continuity check. Thx
I found a resistor that was bad in the section of line 1 at the 12au7 tube. Just fell on it right out of the blue after hours of checking solder connections. Thanks for the help.
The TU8500 works well now. I read that you can change 4 caps to a higher value. What would be the gain in that be?
