Hi from Hyderabad
vikramadityajaiswal
India
Hello,
My name is Vikramaditya and presently I am at Secunderabad. Due to nature of my work I keep relocation every two to three years in the country shuffling between major cities and unheard rural areas.
I have recently been bitten by the audiophile bug and want to get a good Home theatre system for my home as there are awesome content on OTT.
I will be a silent observer since I am a noob in this field and will learn from the respected masters of this blog.
All the best and Cheers!
Welcome to the forum. Since you will be relocating every 2 to 3 years , pls try getting something which is portable and gives good sound quality so you don't end up selling them often.
You can get powered bookshelves and a small subwoofer depending on your room size since ott may be your main source
Hello,
Welcome to HFV.
If the post / response to you helps in any way, use the 'Like' button which is located at the right hand bottom of the post. This helps to build up positive reputation for the FM (Fellow Member).
Hope you have a great journey here!
All the best!
