Hi all,
I am trying to configure my tatasky digicomp to my new harmony 525.Has anyone done this.Suggest me the best way to configure this.I dont have the model number of tatasky remote.
On the logitech software page go to Add a device -> Under the Device select Digital set top box under the cable/ sat option ->Manufacturer Tata Sky -> Put In the model no. of your box.
Its done.
hey Ashish, how would you recommend the Harmony 525? Would it be worth going for or should i go for the cheaper One 4 All remote that costs 2k? (this one is 3.6k)
Egggjactly.On the logitech software page go to Add a device -> Under the Device select Digital set top box under the cable/ sat option ->Manufacturer Tata Sky -> Put In the model no. of your box.
Its done.
Egggjactly.
But having done so, I face a problem. Every click is taken as 2 clicks.
So, if I click down in a list, it goes down 2 places. If I try to type channel 100, the moment I press 1, it takes in 11 on the screen.
It surely is sending out 2 signals. I have successfully tested this. If I click on 1 and after a fraction of time cover the IR emitter in front, the second signal is blocked. Dunno how to sort this out.
Btw:
I've also configured the Airtel box on my 550. It works without a hitch.
Only with TataSky.Is this happening with all your sources or just Tata Sky?
Only with TataSky.
I have almost all other equipment in my signature configured on it. Everything else works fine.
Have you typed the correct model number of the set top box while setting up your remote on the Logitech's software? I would suggest you to configure again and this time add it to the activity list too. Please revert back after performing the above requisites.
I'm using this model no: Tata Sky DSI-3207C Satellite
And it's already added to Activities.
Egggjactly.
Btw:
What is the vendor and model you've selected in the s/w?
Edit: Never mind.. Done!
Hi, I was just wondering what setting you used. I couldn't find the STB in the Harmony software and did not know what model to use.
Thanks!
We use essential cookies to make this site work, and optional cookies to enhance your experience.
