How to connect Airtel HD DTH to Denon AVR 1909
krishna
I have a Denon AVR 1909 Receiver and i recently bought Airtel HD DTH connection. I am unable to connect the DTH box to my AVR through HDMI cable and still get Video upscaling. I have read the Denon user manual which suggests that i need to select Video conversion option to 'ON' to automatically convert the input signals from DTH box. Can someone tell me how this option could be turned on in this Denon Model?
I am using Optoma HD70 (720p) as the output projector.
Here is my current setup.
Airtel Digital HD - connected to AVR through HDMI
Optoma HD70 (720p)- Connected AVR to the projector through HDMI cable.
When i turn on the setup, i am able to see full screen for NGO HD channel, but all other channels look shrunken to half the the width (the hight is normal).
Any help in this regard would be highly appreciated.
Why would you need to upscale a signal that is already being output at 720p by the Airtel set-top box? This is ofcourse assuming that you have set the Airtel set-top box to output at 720p, which is how it should be set since your projector/display is 720p.
