HTPC Help
zoey
India
Hello Guys,
I am planning to build HT for my PC on my own. This system is just for my room. I need suggestions on cheap receivers. I already have decent PC with Creative X-FI soundcard. I also have speakers from an old audio system. ( Front Speakers )
Speaker Specification
3 way bass Reflex ( magnetic shielded type )
Woofer : 160 mm cone type
Tweeter : 80 mm cone type
Super Tweeter : 20 mm creamic type
Impedance : 6 ohms
Output Sound : 87 db/W/m
I will be adding surround speakers later. I have Sony HT DDW685 in my mind. ( although its the full package and priced around 17K )
So can you guys suggest me any good ( also cheap ) receiver less than above range that could work well the above speaker specs. It will be helpful if you could also mention the price ( an estimated price is also fine ) ?
Why not look at active (powered) speakers such as Audioengine 2 or 5? That way you need not look at investing in an amplifier or receiver.
thanks for your response....but I thought I would connect these speakers to a Stereo Amplifier like Norge 1000.... so what's your thought ?
