I.S.C.T. Speaker with dual 'Sealed & Vented' compartment enclosures ....
UpperCut
New Zealand
Hi there,
I have been over the last three month or more working on my drawings for one of my 5 upcoming and new I.S.C.T (Innovative Slice Construction Technique) Sandwich build type enclosure projects, and unfortunately I cant find a lot about the subject at all in my own manual nor the automated research on any of my Server.
If anybody is knowledgeable about this technique of using a dual - sealed as well as vented compartment in an enclosure?
Any help would be greatly appreciated.
Rgs UpperCut
I.S.C.T. Speaker with dual 'Sealed & Vented' compartment enclosures - The 'Build Up' ....
Here are a couple of Images of the first cut Templates for the 'Stand Alone' & the 'Main Build' - very rough at this stage, and of course totally incomplete. rgs UpperCut
http://www.uppercut-audio.webflashartistry.com/AudioImages//MTM1stBuildUp002a.jpg
Hi there,
Thank you very much for associating in genral my work with somebody elses which as well is in or from New Zealand. I had seen this site before but quiet a while ago.
Unfortunately I do not see myself that the technique is similar as first of all his technique he used is very intrigued and is done with a CNC router also looks to be a more commercial set up against my own which is a basic & sole developing DIY approach with a slice construction technique in a vertical or horizontal set up and most of all hand made as of slices created on a table router (every single slice one by one routed to a template(s)). Please if you look at some of my work in other threads (this is really not the best thread for that) you will see that I incorporate into any slice rather then having 7 different pieces and then assemble these.
Some people of course would say that Im also a commercial professional set up, but sorry to disappoint Im actually a 65 year old retired private person able to work 24/7 on my DIY hobby, but in all fairness with a background of three trades and vast experience in electronics, automotive & computer science as MS Engineer & ADOBE Software Developer.
I mean it is only fair to assume anything more because I have had several businesses on the side which predominantly where active in professional promotional work globally (like 60++ countries) so yes I do know how to make my work stand out and how to create an Online Presence with an global visibility even so now it is more used to find my work & to get found, but which in the case of the web site mentioned it is a shame because it is quiet informative say the least, but you do have to be very lucky to trip over it to find it (if at all) in any search for speaker encloures etc.
rgs UpperCut
