Interconnect for TurnTable
AMITNOIDA
Noida
I am going to select a Turntable to add in my chain with Valve integrated amp (Leben Cs300xs) and Usher speaker (BE-718). The speaker wire being used now is Morrow Audio Bi-wired SP-1.
I like wholesome sound with details but can not withstand top end shrill.
Can you suggest few ICs in low to medium budget?
Hi Amitnoida
Try and get the same cable used for tonearm wiring upto the phonostage and even from phonostage to amp, you can try the same cable. That way you will maintain a constant sound signature. Else the Furutech phono cable is very good. It costs about $400.
You can buy some low capacitance video cables(Red,Blue and Green connectors)for connecting TT to phono pre.Try to keep the cable length as short as possible.
Turntable Interconnects... - AudioKarma.org Home Audio Stereo Discussion Forums
Sachin
+1, From this 3 wires, leftover green wire is used by me. It made difference. All around clarity/details increased. I think no more mods required in that area again.
I have taken sachu's advice (in the past) and made DIY interconnects for TTs. The first one I made for my Lenco turned out quite bad because of my wrong choice of coaxial cable (too thick and therefore very inflexible and was a royal pain in the nether regions of the anatomy). The second one I made for a friend's Technics SL 1300 turned out quite good as the choice of cable was better (thin coax cable usually suited for SM-A connector size). For the RCA phono connector, choose something with a small opening in the rubber sleeve. Something like this, but without the flexible spring at the rear.
Neutrik RCA plug black shell with black indicator, NYS373.
Or you can use this type of connector and wrap the spring end with heat shrink wrap (which was what I ended up doing).
The cable would completely depend on what table you are getting. For the scheu, you get a captive lead with RCAs that you can directly connect to you phono stage.
For the VPI, the tonearm wiring is nordost. So nordost is probably the way to go for the cable as well.
The best cables would be the ones that the manufacturer recommends!
Use whatever you have now, get the TT first, hear it and then select an IC accordingly, remember that an IC can be used to fine tune your overall sound
I agree with Odyssey. In case you are DIY type, buy nice Belden cable and high quality Neutrik connectors and solder them well. You have a great interconnect cable.
Thanks Sridhar. I have a spare Audio Art IC-3. So that pair may be used to start with.
Also thanks to Sachin, Anilva, ROC, Joshua, Prem and OMishra for your valuable suggestions.
A shielded interconnect is highly recommended for the TT. The IC-3 is a shielded one
cheers
whatever cable you prefer it should only be low capacitance else you will not get good performance.Most audio interconnects are not suitable for TT application.You can use any moderate budget Video cable(Red+Green+Blue) and keep the length as short as possible(approx 1 meter).
Sachin
This is a post from a facebook group created by yours truly and of which FMs Denom and Santhosh (santhol2?) are admins (besides me, of course). Other than that, many FMs are also members there.
Any other FM(s) here (keen on DIY and custom-bult equipment) desirous of joining this group, please send me a friend request to my facebook profile - "Trittya Tunn" alongwith a message giving me your username on HFV, this being so as its a closed group and NOT OPEN FOR ALL and SUNDRY.
An interesting and useful post by Jacques Barrire of The HI-FI DIY and CUSTOM builders' GUILD here
Log In | Facebook
on the group wall of HI-FI DIY here
http://www.facebook.com/groups?/159629294104826/?ref=notif&no?tif_t=group_activity
QUOTE
Jacques Barrire -
A few reasons why we use DIN connections:
The obvious reason: DIN connections sound better than RCAs...
The phono plug, or RCA connector, as best as anyone can remember, was designed decades ago as a direct current (DC) power connector. Its design properties do not lend themselves to transferring music signals that have very low voltages (less Than 5 volts) of alternating current (AC). This is true - no matter how good the RCA plug is or whether it is made with gold, etc.
The first difficulty with the RCA connector is that it has a high-frequency capacitive impedance of around 200 ohms; unfortunately, the typical cable that connects the two RCA plugs together has an impedance of about 50 ohms. In this situation, the two RCA connectors on either end of the cable act as reflective walls at higher frequencies and bounce information back and forth, trapping the signal and extending the decay time of the signal that is trying to pass from one component to the other. These reflections have an effect on musical information and are especially harmful to low-level signals, particularly quiet harmonics and underlying instruments, where the ringing that is generated by the loudest instruments will smear the smallest signals. The result is that the quiet instruments will blur or fade away when the loud ones come along. The complexities of the music and the tones of individual instruments get lost.
The DIN plug has an impedance that is similar to the cable. It does not reflect like an RCA plug.
Furthermore, the system ground (which should be a stable connection point to which all signals and power supplies are referenced) is absolutely critical to the sonic performance of your hi-fi. A single reference ground point is important so that signal details are not lost in the small, yet significant voltage differences inevitable with separated ground paths.
Many manufacturers point to the great trouble they take to "star ground" everything. Sadly, this is all wasted when you connect your system together with RCA-plugged cables. Why?
When you connect, for instance, a CD player to a preamp with RCA-plugged cable, you automatically have two separate ground wires - the left and right shields going between them. This creates a ground loop, which degrades the musical performance dramatically, and negates any efforts that were taken to ground the internal circuits properly.
If you were to connect these same two components together with DIN-plugged Naim interconnects, you would have only ONE cable with only ONE ground shield surrounding both the left and right signal wires. Hence, only one ground path for each connection and no ground loop.
UNQUOTE
Here is the description of the group. It was created about 10 days back and has 230+ members as on date.
Welcome to the group. I am still in the process of creating it, though.
The aim is to have a common platform where DIY enthusiasts can discuss their projects and/or ideas. Consequently, they can also get their gear custom-made from other members if they so desire.
Its just that there MUST NOT be an overly commercial flavour where people start advertising their gear because that would defeat the entire purpose of going the DIY and/or CUSTOM way.
Having said that, may I request you to suggest appropriate names, even if they are not in my friends' list as of now. There are already some to whom I have already sent a friend request.
It is important that the non-commercial nature and flavour be retained to the maximum possible degree for the benefit of all. So lets all keep it at what we cant do without.
Its pertinent to mention here that (sometimes) a member's name does not get added unless he or she is in my friends' list. Please bear with us till we get these BUGS sorted out.
HOPE THIS HELPS
