Jamo S718 + which amp from the us
corElement
gurgaon / Delhi / NCR
Hello,
I'm planning to buy S 718 Floorstanding Speaker - Description
My sister will be getting the amp from the us because the ones available here are far beyond my budget.
I will be making the purchase from Newegg.com - Computer Parts, PC Components, Laptop Computers, Digital Cameras and more! and I have shortlisted the following.
Pioneer 5.1 : VSX-819H-K
Newegg.com - Pioneer 5.1-Channel A/V Receiver VSX-819H-K
Onkyo 5.1 : TX-SR507
Newegg.com - ONKYO 5.1-Channel Black Home Theater Receiver TX-SR507
Yamaha 5.1 : RX-V465
Newegg.com - YAMAHA 5.1-Channel Digital Home Theater Receiver RX-V465
Sony : STR-DH700
Newegg.com - SONY 7.1-Channel Home Theater A/V Receiver STR-DH700
Sony : STR-DH800
Newegg.com - SONY 7.1-Channel Home Theater A/V Receiver STR-DH800
Why 5.1? because I plan to build up over time, my budget is
10-14k the receiver that will be running off hdmi pref over digital optical.
Total harmonic distortion under 10 if possible?
Also 120v ~ 60v @ 250w how would i run it over here? or do they adapt internally?
Sony : STR-DH800
I would suggest any of the above. Sony being a 7.1 will be a slight advantage over the others in terms of features. Reg the 110- 240 you can get a very good converter or while purchasing in US you can buy one with 240. There are some stores who sell 110 as well as 240. Ask your sister to check before buying.
