I am considering purchasing the LG 65" C8 OLED. There's been a lot of complaints about OLED as a technology wrt burn-in (should be called screen burn really).
From what I have read, the following seems to apply.
1. The Rtings burn tests (with older C7) show that burn in problem is real and appears to showup with around 4000 hours of runtime containing large static content, especially if it is red in color and more-so if it is not interspaced with enough varied content. So if you watch news channel Red tickers (and other static colors to a lesser extent) and logos for 2 hours daily, you could see it in in 4-6 years. Ofcourse you could see it earlier too, but less likely. The burn scenario in the tests are less-likely but possible with people who watch news news and news. Also the 25% window issue (uniformity problems) has been identified by LG and they have confirmed it will not be a problem in C8 panels. They will even fix the older C7 panels free of cost.
2. The newer C8 reportedly has a better and bigger RED subpixel according to this HDTVTest video (watch after 10 min mark) and mitigates to some extent its problem with red static. There is also a Logo Luminescence adjustment feature to further reduce risk.
Anyways it seems the way to reduce the risk is to do the following
1. Dont watch news channels
(or) only watch News channels in cinema mode and not more than 2 hours a day
. Red statics are the worst (remains to be seen if C8 reduces the risk) If you watch more than 50% news - don't get OLED.
2. watch varied content in cinema mode if you can or with less light/brightness.
My questions to 2018 C8 owners
1. Do you watch DTH programs. Has any Logo burn-in occured? What do you do with the Tata Sky logo thats omnipresent at all times? How has it affected your screen?
2. Are you seeing any artifacts/flicker in certain dark scenes with the C8 (not present in C7). Some people are reporting having to increase brightness in C8 to combat this.
Alternatives not good
Looking to go OLED. I thought about going LED route...but I am especially sensitive to the "uniformity issues" and "Dirty Screen Effect" that is prevalent in all LEDs. I watch sports a lot and the camera pans expose LED panel horrors (I have been a plasma guy). Also shows up in some landscape scenes.
