LINUXGURU'S miniRef 1875 Assembling
tnvijay
chennai
Hi all,
just wanted to share my recently completed project.
Anybody who has assembled this or a penasa myref?
Wishing to start a thread on this topology ( Current driven nested chipamps)
Thanks,
Sorry its a high quality image but uploaded from smartphone. Since i am new to forum, dont know how to attach a image properly. Will send you pm if you are interested.
Vijay - you may want to upload your images to an image hosting website, and link the images within your post. As long as they are of moderate size (say less than 50 to 100 kbytes), they will load and display fairly quickly. The syntax for linking the image is "
FWIW, I'm posting this update on this thread - the latest version 1.04 of the MiniRef PCB was delivered to me last week, and I built the first prototype and auditioned it yesterday:
The main improvements are:
1) An improved series-shunt regulator for the opamp supply, with LM317 regulators configured as floating CCSes being the series element, and a zener-BJT beta-multiplied shunt element for each rail. This is the same regulator topology that is used in the MyRef FE.
2) The small-signal split-grounds (one for each channel) as well as the series-shunt regulator ground are AC-decoupled from the power ground, making the small-signal section completely immune and decoupled from the hum and EMI-producing rectifier, filter and chipamp supply section. The result is a completely hum-free dark background, other things being equal.
3) Additional caps in parallel (2x per rail) for the PSU filter section, but it can be populated with just 1x per rail as shown in the pic. This allows some flexibility with the PSU capacitor values - say 2x 2200uF or 3300uF, instead of 1x 4700uF or 6800uF.
4) The rest of the BoM is identical to the previous versions to keep parts sourcing simple.
There is no regression in audible sonics as compared to the earlier version - in fact, even with TDA2050 chipamps, this prototype sounds more detailed than the earlier version with LM1875 chipamps and 2x Black Gate PK capacitors. I'll give an update with audible impressions later, after I've heard more tracks.
Edit: Vijay's v1.02 build uses an optional LF02 hybrid/discrete Class-A opamp module, which provides a relatively laid-back Class-A presentation. The v1.04 gives comparable sonics, even without the LF02 - the upgraded series-shunt regulator makes a significant improvement to the presentation, with more audible bass texture as well as detail in the mids.
...can i integrate this shunt in my existing board?
You can use a small perf board with the regulator components installed on it, and connect it to the main board with 5 wires (which have to be kept reasonably short, say less than 2 cm each if possible).
With a regular mains trafo (EI or anything else) and the LF02 module, the new regulator is not really required. It makes a big difference only if the PSU is an SMPS (like the 2x 19V netbook adapters I mentioned earlier), and a monolithic opamp like the OPA2134 in the outer loop.
Hi sir,
Great info. Wonderful amplifier this one is. This feedback is for the Other forum members who may want to try this unique design of linuxguru.
I will try to post my detailed assembling experience ASAP.
Just a quick update that the LF02 module (with LT1361 SOIC8 dual opamp installed) is also functioning perfectly in the latest MiniRef, with excellent audible Class-A sonics. The plain LT1361 works fine as well.
