Looking for a PC speaker with MIC
vinodtk
india
Hi, I am planning to buy a 2.0 PC speaker with MIC or atleast MIC input. Any suggestions?
Its for call conferencing & Cant use bluetooth.
Googled for 30 mins didnt find anything. Budget is 1000Rs
There is not much PC speakers with in built microphones available, and they will be more expensive like the one listed below.
PC Speaker with mic
If you can use the microphone from pc , then u can simply get the pc speaker alone which should be fit in your budget.
PCs will have seperate Aux/audio output for speakers and input for Mic on the sound card. With the budget you are having, you can look in OLX for used PC speakers like Creative, logitec or Zebronics. Plus, buy a stand mount PC mic available in Amazon around Rs. 300. Certainly, you will not get good and reputed brands with in the specified budget.
PC Speaker with mic
Already suing that setup. But i was looking for a better looking setup.
In that budget, I don't think there is anything better than creative.
Deal of the day: Creative T60 2.0 Compact Hi-Fi Desktop Speakers with Clear Dialog and Surround by Sound Blaster, USB-C Audio, Mic and Headset Ports, Bluetooth 5.0, Up to 60W Peak Power, for Computers and Laptops https://amzn.eu/d/idPstB9
MaSh
My experience, desktop mic + speaker setups for video conferences will need a high gain , directional mic + some active noise cancellation to reject feedback/echo from speakers. You're looking at very expensive poly/Jabra hardware here. Not going to happen in this budget. I tried a plantronics calisto usb speakerphone off OLX, didn't like it and went back to my evolve 75 headset. It's by far the best
